MemphisT
Dec 29, 2015Aspirant
READYNAS Pro 6: What is a BLSNFO file?
I'm a nooby to ReadyNAS storage. So my question may be simple to experienced people and appreciate the patients. What is a BLSNFO Files in a readynas folder? The NAS automatically makes this BL...
- Dec 30, 2015
I don't think any of our services would create these. I think it must be some software on your PC.
MemphisT
Dec 30, 2015Aspirant
Which OS is on the client machine? Windows 10 / I also use MAC OS X _ El Capitano (Mainly Windows 10 though)
Which firmware is on the NAS? 4.2.27 : ReadyNAS Pro 6
Which protocol are you using e.g. SMB?
Windows 10 uses the Microsoft SMB Protocol (SMB) Protocol, That is what I use
MAC OS X: I use smb through the server connect, Normally MAC OS X would use AFP (Apple Filing Protocol). This is the Apple's native file sharing protocol for mapping network drives, I never use that.
How are you copying the data onto the NAS?
I have a mapped network drive and use explorer to Cut and Paste.
I was using Teracopy for a few weeks but it was buggy and not as quick as it cliams. I removed it a few weeks ago.
Thank you
