MemphisT
Dec 29, 2015Aspirant
READYNAS Pro 6: What is a BLSNFO file?
I'm a nooby to ReadyNAS storage. So my question may be simple to experienced people and appreciate the patients. What is a BLSNFO Files in a readynas folder? The NAS automatically makes this BL...
- Dec 30, 2015
I don't think any of our services would create these. I think it must be some software on your PC.
SeniorD
Jul 16, 2017Aspirant
What does NAS mean and do? It is part of my Model No. There was a version update shortly after purchase and when I typed my model # into a Net gear search it said, "not found."
TeknoJnky
Jul 16, 2017Hero
definately some kind of 3rd party cataloging file, they look similar to metadata files used by KODI, but I've never seen that file name though so no idea what program.
http://kodi.wiki/view/NFO_files
What media player are you using when playing from the nas?
I bet they are coming from one of your xstreamers, probably using some customized fork of xbmc/kodi.
