popguru
Sep 19, 2019Aspirant
ReadyNAS Pro 6 won't start up
Hi there, We recently moved house and, having unpacked my tech stuff, I've just plugged in my trusty ReadyNAS and, er, nothing happens, other than some flickering on the status lights on the LAN por...
- Sep 27, 2019Fixed! I’ve taken every connection off and cleaned them up, mounted the new owner supply externally and it’s booted up and discoverable. Thanks all for your help!
Sep 19, 2019Guru - Experienced User
I'd make sure all the trays are all the way. Also, take off the side cover and make sure the memory is seated.
