popguru
Sep 19, 2019Aspirant
ReadyNAS Pro 6 won't start up
Hi there, We recently moved house and, having unpacked my tech stuff, I've just plugged in my trusty ReadyNAS and, er, nothing happens, other than some flickering on the status lights on the LAN por...
- Sep 27, 2019Fixed! I’ve taken every connection off and cleaned them up, mounted the new owner supply externally and it’s booted up and discoverable. Thanks all for your help!
popguru
Sep 27, 2019Aspirant
A quick update. Having taken the sides off, I checked the memory and it was indeed seated properly.
I’ve therefore bitten the mullet and ordered a replacement power supply with associated extender and converters, which should arrive today. I’ll post further once it’s arrived and (hopefully) fitted.
popguru
Bitten the mullet.... I’m not even going to correct that, it shall lie on file.
