popguru
Sep 19, 2019Aspirant
ReadyNAS Pro 6 won't start up
Hi there, We recently moved house and, having unpacked my tech stuff, I've just plugged in my trusty ReadyNAS and, er, nothing happens, other than some flickering on the status lights on the LAN por...
- Sep 27, 2019Fixed! I’ve taken every connection off and cleaned them up, mounted the new owner supply externally and it’s booted up and discoverable. Thanks all for your help!
popguru
Sep 27, 2019Aspirant
I have received and installed a new power supply (Seasonic SSP-300SFG). The good news is that the unit now has power but it is stuck showing 'ReadyNAS' on the display. I've had a quick search and it's not looking good, for example in this similar thread:
I have tried resetting but nothing happens. Also, the main NAS fan above the power supply is working but there are no LAN lights illuminating. I've tried various leads on both ports and different ports both on my router and on some Devolo Magic 2 units installed around the house, with the same result. Obviously Raidar isn't finding it either.
Is there any way to get my data off the discs? Or any other suggestions?
Thanks,
Martin
Sandshark
Sep 27, 2019Sensei
The NAS will display "ReadyNAS" if just the 5V of the supply is working, so a lot could be wrong. The first thing to check is that all the power supply connections are fully seated, especially the 24-pin extender cable (assuming you needed one) and the square 4-pin 12V CPU power connector (which is easy to forget to install). Also check that the RAM is properly seated, as you likely had to remove it to plug in the 24-pin connection. Make sure you didn't damage anything in the process of replacing the supply.
If nothing looks wrong, and assuming the new supply isn't partly DOA, then your supply may have taken the NAS with it when it died.
