TWilson's avatar
TWilson
ReadyNas Pro and G.SKILL F2-6400CL5D-4GBNT
Installed the following 4GB kits in two separate identical ReadyNAS Pros. Tested good in both (4 Memory Test Passes in each Pro).
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 800 (PC2 6400) SDRAM Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBNT
• Timing 5-5-5-15
• CAS Latency 5
• Voltage 1.8V
Lifetime Warranty
$59.99 at newegg.com http://www.newegg.com/Product/Product.aspx?Item=N82E16820231207
I also upgraded the CPU in both Pros from the stock:
Intel E2160 Pentium Dual-Core SLA8Z 1.80GHZ/1M/800/06 / L950B254
to the:
Intel Core 2 Duo 6700 SL9ZF 2.66GHZ/4M/1 066/06 / L644G421
Also installed and attached a VGA DB15F connector to the VGA Header.
So far the ReadyNAS Pro is running great.
ProSupport for Business
