-Cos-
Dec 29, 2020Aspirant
ReadyNAS Pro Business Edition (RNDP6610 ) - Power Supply Replacement
Just thought I would share with the community, I recently replaced the power supply in my ReadyNAS Pro Business Edition (RNDP6610) and located a drop in modular replacement that worked quite well. ...
-Cos-
Dec 30, 2020Aspirant
- StephenBDec 30, 2020Guru - Experienced User
Thx for sharing. People do come here looking for PSU replacements, and it is helpful to have info on specific supplies that work.
- SandsharkDec 30, 2020Sensei
650W, 80+ Gold is certainly overkill for a 6-bay NAS, but it's also bound to last forever and is likely a lot more quiet. I actually had a failure of a replacement Seasonic (when they were still available), so the added cost of a better supply might have been worth it vs. two replacements. The modular construction so you can remove unneeded cables is also nice.
Did it already have the three 4-pin Molex connectors, or did you need an adapter or splitter?
- -Cos-Dec 30, 2020Aspirant
They make them in 550, 650, 750 & 850W. I purchased the 650 because they were out of the 550 at the time I was looking and the price difference between the two was nominal.
Connectors it comes with:
1 x ATX 24 Pin
1 x EPS 4+4 Pin
1 x EPS 8 Pin
8 x SATA
4 x Peripheral 4 Pin - Molex
4 x PCI-e 6+2 PinMfgr Product Page:
https://www.coolermaster.com/catalog/power-supplies/v-series/v650-sfx-gold/
Product Sheet: https://coolermaster.egnyte.com/dl/7b7ve4j7j4
Manual: https://coolermaster.egnyte.com/dl/P356gRQZFE
