Dave_Ams
May 03, 2015Tutor
ReadyNas Pro died
I recently moved house and when I came to reconnect my ReadyNas Pro buisiness it gave no signs of live beyond blinking network lights. The fans and the disks don't spin up the front display doesn't li...
mdgm-ntgr
Jun 28, 2015NETGEAR Employee Retired
The 316 does have a slower CPU than the one in the Pro.
If the memory is not swapping then the benefits of a memory upgrade will largely be marginal. The web interface is low priority so if other services such as the SABnzbd app are hogging resources then you will likely see reduced performance from the web interface.
