qtzar
Nov 17, 2011Aspirant
ReadyNAS Pro disk in bay 5 keeps failing [17175701]
This has been driving me insane. When I try to copy a LOT of files off the ReadyNAS one of the disks starts reporting as failed. It seems to be either channel 5 or channel 2. I've replaced the f...
qtzar
Nov 18, 2011Aspirant
The disks that have been reported as bad. Do you think they are really bad or could it just be the back pane. Haven't heard anything from netgear Support yet so just planning on what to do with those disks.
If i reset with the bed disks in the unit would they start being recognized again or should I save them to put into a diskless unit that I might buy as backup?
