Labdoc1
Jun 20, 2020Luminary
ReadyNAS Pro OS6.10.3 Unresponsive until hard boot
Since OS 6.10.3, my RNAS completely hangs up at irregular intervals, for example May 28, June4 and today June 20. Holding the power button to shut down and then restart is the only fix. The logs...
Marc_V
Jun 21, 2020NETGEAR Employee Retired
@abdoc1
It would be best if you can provide us through PM the full logs of the NAS. It might be possible that the OS Volume or Data volume is at a level where the performance is being degraded or other cause might be found.
many thanks!
Labdoc1
Jun 21, 2020Luminary
Please check your private messages
