Greg_Staten
Jan 30, 2015Tutor
ReadyNAS Pro Pioneer resync stuck at 58.6%
I have a Pro Pioneer that I use as a home media and backup server. Last week the performance fell into a deep ditch and I'm struggling/concerned to bring things back to normal. Ten days ago the wee...
Jan 30, 2015Guru - Experienced User
What firmware are you running? You can also see the health if you download the logs.
You might also try IE in "compatibility mode".
Lifeguard tests are non destructive (some advanced tests are destructive but they warn you before they proceed). You'll want the NAS shutdown when you remove drives. Windows won't mount the drives, but lifeguard will see them.
