kekegsm
Mar 28, 2017Guide
ReadyNAS pro: Q6600 working, E7600 not...
Hi All, I bought an used ReadyNAS Pro. The last owner changed the CPU to Q6600, the CPU cooler to a Schyte Kodati. But for me the E7600 enough, and use less power/make less heat. 105W vs 65W, th...
- Mar 28, 2017
In the logs there is bios_ver.log. The latest BIOS is from 07/26/2010
There's a very long thread on this: https://community.netgear.com/t5/Community-Add-ons/More-on-CPU-specs-of-the-ReadyNAS-Pro/td-p/635055
kekegsm
Mar 28, 2017Guide
how can I check the Bios version? And where can I find the latest BIOS for it?
It is an RNDP6350
The motherboard version is: FLAME6 v1.1 (between the CPU and the RAMs)
mdgm-ntgr
Mar 28, 2017NETGEAR Employee Retired
