spiderman1
Sep 07, 2016Guide
Readynas Pro Rebooting After Shutdown
Hi guys, My Pro running OS 6.5.1 continually reboots after shutdown both via UPS and direct socket modes. This started to happen when I moved my unit to another room and was putting back all the...
mdgm-ntgr
Sep 07, 2016NETGEAR Employee Retired
Those are likely suspects, yes.
There are some suggestions on PSU and an extender cable for it on the community.
- spiderman1Sep 07, 2016Guide
If I realize that the problem is the PSU, where can I get a replacement for it? This is a Pro BE.
Many thanks as usual.
- StephenBSep 07, 2016Guru - Experienced User
https://community.netgear.com/t5/ReadyNAS-in-Business/Spare-ReadyNAS-Pro-6-Power-Supply/td-p/1006575
- spiderman1Sep 12, 2016Guide
If I understood correctly, I will need to purchase the following PSU and cables for the PRO BE:
1. SeaSonic SS-300SFD.
2. a 24 pin extender - you might as well get them while you are at it.
3. 3 (4-pin molex connectors)
Does Netgear perform PSU replacements even if the unit is no longer under warranty?
