spiderman1
Sep 07, 2016Guide
Readynas Pro Rebooting After Shutdown
Hi guys, My Pro running OS 6.5.1 continually reboots after shutdown both via UPS and direct socket modes. This started to happen when I moved my unit to another room and was putting back all the...
mdgm-ntgr
Sep 07, 2016NETGEAR Employee Retired
Those are likely suspects, yes.
There are some suggestions on PSU and an extender cable for it on the community.
spiderman1
Sep 07, 2016Guide
If I realize that the problem is the PSU, where can I get a replacement for it? This is a Pro BE.
Many thanks as usual.
- StephenBSep 07, 2016Guru - Experienced User
https://community.netgear.com/t5/ReadyNAS-in-Business/Spare-ReadyNAS-Pro-6-Power-Supply/td-p/1006575
- spiderman1Sep 12, 2016Guide
If I understood correctly, I will need to purchase the following PSU and cables for the PRO BE:
1. SeaSonic SS-300SFD.
2. a 24 pin extender - you might as well get them while you are at it.
3. 3 (4-pin molex connectors)
Does Netgear perform PSU replacements even if the unit is no longer under warranty?
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
We don't do PSU replacements for units out of warranty, but you can at your own risk attempt PSU replacements.
We do have a procedure for using a new x86 ReadyNAS (RN316/RN516/RN716X/RN526X/RN626X) to attempt to recover data from a dead legacy x86 NAS: Migrating disks from RAIDiator to OS6 (this assumes you were running RAIDiator-x86 4.2.x on the old x86 ReadyNAS. If you were running OS6 on the legacy x86 ReadyNAS it's a much more straightforward migration).
But obviously getting a new NAS and having somewhere to backup the data from the dead NAS to is considerably more expensive than just replacing the PSU.
