SeanLavelle
Feb 18, 2022Aspirant
ReadyNAS R104 power connector
I have a loose connection to my 104. It happened when I tried to remove the power cable, it was very stiff when removing it. How can I tell which is at fault, the power board inside the nas, or the c...
Sandshark
Feb 18, 2022Sensei
With the cable removed, can you see the internal connector move when you push on it with something? If so, it's likely broken solder joints at the connector to board interface.
- SeanLavelleFeb 18, 2022AspirantThanks. I will look at that tomorrow.
- SeanLavelleFeb 20, 2022Aspirant
It appears to be the cable. It is very very hard to pull out. It doesn't slip out easily.
- SandsharkFeb 21, 2022Sensei
Well, that's the more easily fixed side. When you go to buy a replacment, be aware that not all manufacturers use the same pin-out for the 4-pin DIN. Make sure you look at the pin diagram or buy one listed as for a ReadyNAS or Synology (which uses the same pin-out).
