SeanLavelle
Feb 18, 2022Aspirant
ReadyNAS R104 power connector
I have a loose connection to my 104. It happened when I tried to remove the power cable, it was very stiff when removing it. How can I tell which is at fault, the power board inside the nas, or the c...
Sandshark
Feb 18, 2022Sensei
With the cable removed, can you see the internal connector move when you push on it with something? If so, it's likely broken solder joints at the connector to board interface.
SeanLavelle
Thanks. I will look at that tomorrow.
