SeanLavelle
Feb 18, 2022Aspirant
ReadyNAS R104 power connector
I have a loose connection to my 104. It happened when I tried to remove the power cable, it was very stiff when removing it. How can I tell which is at fault, the power board inside the nas, or the c...
SeanLavelle
Thanks. I will look at that tomorrow.
SeanLavelle
Feb 20, 2022Aspirant
It appears to be the cable. It is very very hard to pull out. It doesn't slip out easily.
- SandsharkFeb 21, 2022Sensei
Well, that's the more easily fixed side. When you go to buy a replacment, be aware that not all manufacturers use the same pin-out for the 4-pin DIN. Make sure you look at the pin diagram or buy one listed as for a ReadyNAS or Synology (which uses the same pin-out).
