robturpin
Jul 24, 2016Apprentice
ReadyNAS RAM Upgrade - Needed?
Hello everyone. I just bought a used ReadyNAS Ultra 6 (RNDU6000-100), loaded with six 2TB drives. I've read that this unit originally came with only 1GB of RAM, but mine has a single 2GB DIMM. I just...
- Jul 24, 2016
2GB should be more than enough. We do use available memory for caching to improve performance and free it up as needed. Unless you are seeing swap being used the benefits from upgrading the memory would be minimal.
Some advanced users install things like Crashplan or setup VirtualBox (though you would be limited to 32-bit VMs as your CPU doesn't support VT-x) using SSH. Both of these lots of RAM. But for most users who don't use things like those 2GB will be more than enough.
robturpin
Jul 26, 2016Apprentice
Good deal, thanks man!
