poko2121
Dec 29, 2015Aspirant
readynas read directory speed
Hi I recently replaced my office windows 2003 server with a readynas 312 file server. I noticed that with the readynas browsing files through the finder on mac was a lot slower than when i did it wi...
mdgm-ntgr
Dec 29, 2015NETGEAR Employee Retired
Which protocol are you using on your Mac? SMB or AFP?
Which services and apps are you running on your NAS?
poko2121
I am using SMB. I tried it with AFP and it was a little faster on the benchmark, but nothing noticeable in real use
- mdgm-ntgrDec 29, 2015NETGEAR Employee Retired
There is a backend settings change for SMB that I could try. Sent you a PM.
Well, the backend change resolved the problem!
poko2121 wrote:
Helios benchmark is still saying 150ms read directory time which is a lot slower than the old server got (15ms) but it feels just as quick thanks so much!
- poko2121Dec 29, 2015Aspirant
Thanks so much mdgm!
