Co_Louth
Jul 02, 2017Tutor
Readynas Remote
Hi Guys, Got a problem with a readynas connection error. Everything was working fine up till last Saturday 01.07.2017 when it just stopped working.We have not changed anything and I have tried l...
- Jul 04, 2017
The concern has something to do with the problem we are encountering with our VPN server. A fix has been deployed from our VPN server to address the concern and it does appear that your NAS is back in business. Since the issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regard,
Marty_M
NETGEAR Community Team
Co_Louth
Jul 03, 2017Tutor
Hi Marty_M
Thanks for the reply and the welcome,
Yes, trying to access remotely.
Both the cloud and internet have green check marks and the 3 ReadyNas server (box's) are running fine inhouse and also over owncloud and readycloud.
It's just that on my PC at home I have some files as "Shares ie; T//filename " and all was great for over a year until the first of July 2017.
Been trying all day to live chat with someone at Netgear but they keep telling me to try again in an hour or so.
Many Thanks for the reply
Martin
nasuser800
Jul 03, 2017Tutor
I am having the same issue. I spoke to Netgear support, and on the call it was determined that the NAS was functioning properly. I was able provided posts showing that other users were experiencing same issue. Support team is checking to see if there is an outage.
