akahige1
Jan 29, 2017Aspirant
ReadyNAS replacement chassis compatibility question
I have a ReadyNAS RND 4000. The chassis died but the drives are still good. I was told that the file system on that unit isn't compatible with newer ReadyNAS products, so my only recourse to acces...
Jan 29, 2017Guru - Experienced User
A sparc-based rackmount would also work (for instance the readynas 1100). It's probably easier to find an NV+.
If the PSU failed on the old chassis, you can replace that. There is a pinout modification that needs to be made if you purchase an off-the-shelf supply. There are a few direct replacement supplies out there (where the mod has already been done), but they do tend to be expensive.
There are a couple of alternatives for off-loading your data. The volume can be mounted on an x86 linux system - http://home.bott.ca/webserver/?p=306
Netgear support can also help you mount the volume temporarily on a new OS 6 readynas so you can offload the data. I believe they will charge (not sure though). Details are here: http://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6?cid=wmt_netgear_organic
mdgm-ntgr
Jan 29, 2017NETGEAR Employee Retired
You should consider that NV+ units would be several years old by now and that second-hand units may be in questionable condition.
