Cabadam
Jun 29, 2014Aspirant
ReadyNAS reporting drive failure
I previously had 3x Seagate 1.5 TB drives in my ReadyNAS NV+ (v1). Recently, it reported a drive failure on drive #3, and sure enough, it was making a horrible noise. The drives I have aren't in p...
Cabadam
Here's the SMART info reported by the ReadyNAS:
SMART Attribute
Spin Up Time 0
Start Stop Count 9
Reallocated Sector Count 0
Power On Hours 1560
Spin Retry Count 0
Power Cycle Count 9
Runtime Bad Block 0
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 0
High Fly Writes 0
Airflow Temperature Cel 38
G-Sense Error Rate 0
Power-Off Retract Count 9
Load Cycle Count 11
Temperature Celsius 38
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Head Flying Hours 254777460000279
Total LBAs Written 10220811386
Total LBAs Read 2006893
ATA Error Count 0
Extended Attribute
Hot-add events 5
Hot-remove events 5
Lp stat events 5
Power glitches 0
Hard disk resets 4
Retries 2
Repaired sectors 0
SMART Attribute
Spin Up Time 0
Start Stop Count 9
Power On Hours 1560
Spin Retry Count 0
Power Cycle Count 9
Runtime Bad Block 0
End-to-End Error 0
Command Timeout 0
High Fly Writes 0
Load Cycle Count 11
ATA Error Count 0
Extended Attribute
Hot-add events 5
Hot-remove events 5
Lp stat events 5
Power glitches 0
Hard disk resets 4
Retries 2
Repaired sectors 0
