Apota4U's avatar
Apota4U
Tutor
Dec 14, 2019
ReadyNAS Restoring Backed Up Files
So, I've been backing up all my files from all of my computers on my home network using the ReadyCLOUD app. I purchased a new computer and I need to copy all the files from the ReadyNAS to the new PC...
  • Apota4U's avatar
    Apota4U
    Dec 16, 2019
    I actually figured it out already. You use the ReadyCloud app to restore it to any computer you want. You select the backup folder you want to copy to the computer you are logged into and you choose the sync option for that folder and it copies all the files from that folder to your netgear folder for that user that's logged in data location.
ProSupport for Business
