blushark
Mar 12, 2022Aspirant
ReadyNas RN102 has no power but usb does
So I got home from vacation and my ReadyNas RN10223D was powered off. I tried everything, but I could to get it to turn on...no lights anywhere and no fan. I swapped out another ReadyNas power supply...
Mar 12, 2022Guru - Experienced User
blushark wrote:
I swapped out another ReadyNas power supply brick plug and still did not work.
What model ReadyNAS did the second brick come from?
blushark wrote:
can I find a similar unit I can just buy and insert my current drives and have access to my drives?
The disks can be directly migrated to any OS-6 ReadyNAS.
blushark wrote:
I could see the volume and it showed all three partitions as healthy, but I could not assign it a drive letter to pull in up in windows explorer.
That is normal, because Windows doesn't include support for mdadm RAID or the BTRFS file system.
However, there are open-source packages for both mdadm and btrfs that you could try.
blushark
Mar 24, 2022Aspirant
how do I konw if its a mdadm RAID or the BTRFS file system?
- StephenBMar 24, 2022Guru - Experienced User
It's both. mdadm RAID creates a virtual disk, which holds the BTRFS file system.
- blusharkMar 24, 2022Aspirant
ok so I have to install both and start with the mdadm RAID first?
While I know others have used these packages on their Windows PCs with success, personally I've only run mdadm and btrfs on linux.
You do need to install both. But I think you can just run btrfs.
