blushark
Mar 12, 2022Aspirant
ReadyNas RN102 has no power but usb does
So I got home from vacation and my ReadyNas RN10223D was powered off. I tried everything, but I could to get it to turn on...no lights anywhere and no fan. I swapped out another ReadyNas power supply...
blushark
Mar 24, 2022Aspirant
how do I konw if its a mdadm RAID or the BTRFS file system?
Mar 24, 2022Guru - Experienced User
It's both. mdadm RAID creates a virtual disk, which holds the BTRFS file system.
- blusharkMar 24, 2022Aspirant
ok so I have to install both and start with the mdadm RAID first?
- StephenBMar 24, 2022Guru - Experienced User
While I know others have used these packages on their Windows PCs with success, personally I've only run mdadm and btrfs on linux.
You do need to install both. But I think you can just run btrfs.
