jama
Jan 01, 2014Aspirant
ReadyNAS RN10200 Sufficient ?
I have a ReadyNAS Duo v1 which I am looking to replace. I have only ever used this at its most basic, storing all my data under a single file share giving me plenty of space and some redundancy. W...
mdgm-ntgr
Jan 01, 2014NETGEAR Employee Retired
Get the 312. It can do some transcoding and remuxing whereas with the 102 you would need the video to be in the exact format that your client device will play.
The 312 has an Intel Atom CPU so it will run a greater variety of apps and the 312 has a HDMI port for possible future use.
Teaming would be unlikely to improve performance on the 312 which has an Atom CPU, however some teaming modes would provide automatic failover so if one of your NICs fails your NAS will stay connected to your network using the other one.
