nsoderi
Apr 13, 2019Follower
ReadyNAS RN104 - System volume root's usage is 86%. /dev/md0
Hi,
I started receive the below alert.
Before came here, tried to do it myself but don;t know if the /dev/md0 is a file or directory, if can be deleted or not, if needs to be monted or not e...
Apr 13, 2019Guru - Experienced User
One option is to use paid netgear support (my.netgear.com).
Instructions for dealing with the AntiVirus issue are here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-90-RN102/m-p/1723405#M178497
