JuneWinters
Apr 15, 2025Aspirant
ReadyNAS RN104 Drive degraded, ATA error
Hi all, I have a ReadyNAS RN104 that it seems has a drive that is going kaput. I thought I had alerts set up but seems they were going to an old email address and so I haven't been getting the 4 ...
- Apr 15, 2025
JuneWinters wrote:
When I look in overview it says Degraded. I gather this means the drive itself is old and needs replacing (and fingers crossed it shouldn't be a problem with the NAS connection to the drive).
Your RAID array has single-disk redundancy. That means you can still get to your data even if one drive fails.
The "degraded" status is for the full volume of four disks, and it means that the NAS has already decided that disk 2 has failed, and has stopped using it. So your data is definitely at risk, since if there is a problem with another drive you will lose all your files.
JuneWinters wrote:
1. Forum discussions I have seen say to simply switch out the failed disk and replace it. However, is any further backup required first?
Devices can fail at any time, and your data is particularly vulnerable right now. Netgear recommends backing up your data before manipulating disks, and I agree with that guidance. However, you don't want to delay the replacement either. So order the replacement disk (another Ironwolf is fine), and start backing up while you wait. You might also order a USB drive to give you space to back up.
You should prioritize unique content (documents, family photos and videos) that cannot be replaced. You might already have enough storage (thumb drives, or PC disk space) to hold the personal files. If not, you could purchase cloud storage from Google (or others), and copy the files to Google Drive (or equivalent). 2 TB of storage costs about $10/month. 2 TB won't be enough to copy all your files, but likely will be enough for the personal files.
Then back up media (music, movies, etc). after the personal files are safe.
JuneWinters wrote:
I.e. as my large media folders aren't being backed up, setting these to backup internally in the NAS would be worthwhile if changing out Disk2?
To be clear - your data is spread over all 4 of your disk drives. Making another copy of these files on your NAS is a waste of your time. If the volume is lost, all the files on the NAS will be lost with it. Backups need to be made to another device.
JuneWinters wrote:
. Is there a way to tell if it is the disk itself that has failed or an issue with the NAS?
The reallocated sectors are definitely pointing towards the disk, and not the NAS. If you can connect the disk to a Windows PC (with SATA or a USB adapter/dock), you could test it with Seatools to confirm.
JuneWinters wrote:
3. Is there anything else I need to know or check re data resilience before I pull the drive out and put a new one in?
I always test my replacement drives first (using Seatools in a PC), before I put them into the NAS. Note you shouldn't (and don't need to) format them in the PC. I run the full non-destructive "long" test, and follow that up with full disk write test (one pass). If both tests pass (and sometimes one or the other fail), I proceed with the disk replacement.
I recommend hot-swapping the drive (NAS running when you remove it and insert the new one). But you do need to be very careful to remove the correct drive, and leave the others connected. So if you aren't certain you can do that successfully, then power down the NAS, and remove disk 2 first. After that, you can power up - the NAS will still show a degraded status. Then hot-insert the replacement.
Note that you can download the full log zip file from the NAS web ui. Disk_info.log will give you the serial number for disk 2 (and should also show the reallocated sectors and the ATA errors). If you power down and remove the disk, you can then double-check the serial number before you power the NAS back up again.
If you like, you can send me a PM (private message) with a link to the zip, and I can look for any other issues in the logs. You send a PM using the envelope icon in the upper right of the forum page. You'll need to upload the zip to cloud storage (google drive, dropbox, etc), and include a link in the PM. Make sure the link permissions are set so anyone with the link can download.
Apr 24, 2025Guru - Experienced User
JuneWinters wrote:
Thanks all. Backup done onto external disks due to the recent incompatability with Google cloud feature. Failed disc hotswapped and took 3.5 days to rebuild (seems an outrageously long time). Showing as healthy again and no data loss that I can see. Appreciate the info.
Were you doing the backup during the resync? That will slow down the resync.
You might download the log zip file and look for disk errors (just in case another drive is acting up). Kernel.log, System.log, and Systemd-journal.log are good places to look (though they can be intimidating).
JuneWinters
Apr 24, 2025Aspirant
No, I made sure all backup was completed in advance to prevent issues if things went awol. Will have a look at the logs you mention to see if anything shows.
