RJKJFrost's avatar
RJKJFrost
READYNAS RN10400 Dead line of blue squares
Hi everyone.
Our ReadyNas Rn10400 seems to be dead?
When plugged into power (we have tried multiple outlets) all we can get is a line of blue squares on the display.
Pushing the power button does nothing, pushing and holding the power button does nothing.
We have had no power outages or any issues like that as far as we are aware.
We have tried to open the boot menu by unplugging the unit, holding the reset button in and pluggin it back in, and we still only get the blue squares on the screen.
We can not hear any noise from the system at all. We have tried turning the unit on without any drives in it and we get the same issue.
Does anyone have any ideas as to what may be going on please?
Thanks for your time.
  • Plugging it in now and I don't even get the blue lights. Nothing. No response at all to power?
    • StephenB's avatar
      If you purchased the NAS new, then it is covered by the three-year warranty.  So I'd start by checking the warranty status.  If you are covered, use Netgear paid support (my.netgear.com).  Don't sign up for gearhead.  Instead look for a link saying that you are requesting a warranty replacement.
      If you aren't covered by warranty, then you could try to do a risk-buy of a new power adapter.  The NAS chassis isn't repairable, so if that's the problem you'll need to replace it.  The RN200 series is the current entry-level NAS - significantly faster than your RN104.
      I do suggest removing the disks, and see if you get a different symptom when you power up.  Label them by slot as you remove them.
      • RJKJFrost's avatar
        RJKJFrost
        So I'm trying to check the warranty status however I think the system was replaced by readynas under warranty not too long ago. My system says that I purchased it in 2014 however I'm sure it has since been replaced. I am trying to contact support to check on the warranty and I go through all of the support online stuff I need to so that I can call and then I get to the part where it's supposed to give me a number and I get a "please quote this number" screen, but it has no number, just a red box. (please see attached image). I try to call support and can't get through without a number. HOW do i get a hold of someone to check the actual warranty status please (as this is an odd case) or even to order replacement parts. So frustrated.
ProSupport for Business
