sbfielding
Oct 13, 2016Aspirant
ReadyNAS RN2120 Does Not Show All Discs Under Volumes
I am trying to set up my ReadyNAS RN2120. I bought this as a diskless unit and have added 4x Western Digital WD40EFRX 4TB SATA drives. All matched, all the same. Strange thing is that the NAS only se...
sbfielding
Oct 14, 2016Aspirant
Thanks for replying to my post.
The NAS is running firmware 6.6.0.
This is a screen shot of the problem...
All four bays have drives fitted. All four were new, as far as I was concerned and had not been formatted. Is there any way that I can find out if they have already been formatted?
- StephenBOct 14, 2016Guru - Experienced User
Thanks, the screen shot helps. First I'd try swapping disk-1/disk2 and disk-3/disk-4. You can do this with the NAS running.
If the problem follows the disks, then check the undetected disks with WDC's lifeguard program in a Windows PC.
If the problem remains (and doesn't follow the disks), then try rebooting the NAS.
