Chapi
Jun 20, 2020Aspirant
ReadyNAS RN214 check root fs - booting 47% - stalled
round I have a RN214 runninfg V6.10.2 (downgraded from V6.10.3 a month or 2 ago). I had to unplug the unit after it became un-responsive (again) but this time, instead of rebooting normally, it ...
- Jun 21, 2020
If the NAS is used, then Netgear won't provide paid support. readynasd is the Netgear NAS application itself.
Have you tried booting up the NAS read-only? Probably worth doing before you try going into tech support mode.
Though if this isn't critical, I'd suggest just doing a factory default and rebuilding the NAS.
Jun 21, 2020Guru - Experienced User
The btrfs errors cause me to suspect the /data filesystem is corrupted (though it does sound like root is messed up also).
Do you have a backup of the data?
Chapi
Jun 21, 2020Aspirant
StephenBThis now failing NAS is use to backup 3 other NAS that I own. I am exploiting btrfs snapshots to keep multiple versions of files that changed on the 3 other NAS.
There is a few files that I'd really like to get to on the /data partition but, assuing the none of the other 3 NAS dies on me, I have no critical data on the failing NAS that I cannot recreate.
Should I have seen warnings about the btrfs errors? Was there a way to check the health of the btrfs /data partition before it died on me?
Thanks.
