Chapi
Jun 20, 2020Aspirant
ReadyNAS RN214 check root fs - booting 47% - stalled
round I have a RN214 runninfg V6.10.2 (downgraded from V6.10.3 a month or 2 ago). I had to unplug the unit after it became un-responsive (again) but this time, instead of rebooting normally, it ...
- Jun 21, 2020
If the NAS is used, then Netgear won't provide paid support. readynasd is the Netgear NAS application itself.
Have you tried booting up the NAS read-only? Probably worth doing before you try going into tech support mode.
Though if this isn't critical, I'd suggest just doing a factory default and rebuilding the NAS.
Chapi
Jun 21, 2020Aspirant
SandsharkI am looking preferably for instructions on how to repair/replace the main filesystem so I can fix it myself if it ever happens again.
I bought that NAS used so I have no formal support. I would have to check how much Netgear charges for looking into this and fixing it (assuming they charge only if the repair of the main filesystem is sucessful)...
I have seen posts from members of this community fixing similar problems so that is an option too...
What is the purpose of readynasd? Is there supposed to be more than 1 active at any given time?
Thanks
Jun 21, 2020Guru - Experienced User
