Obiwan_
Feb 05, 2023Apprentice
ReadyNas RN2304 Using Large capacity SSD (16TB) connected to USB
I have four RN2304s with max capacity on one of 28TB. I have been trying to set up backups using attached USB drives. So far I have used mechanical USB drives to capacity of 5TB without any problem. ...
Sandshark
Feb 05, 2023Sensei
The ReadyNAS OS does not support ExFAT, so don't keep trying that. It should support GPT/NTFS without regard to it being an SSD or mechanical hard drive. But it does not support a drive having a GPT protective partition. When it does show up, what happens if you try to reformat with the NAS?
