Obiwan_
Feb 05, 2023Apprentice
ReadyNas RN2304 Using Large capacity SSD (16TB) connected to USB
I have four RN2304s with max capacity on one of 28TB. I have been trying to set up backups using attached USB drives. So far I have used mechanical USB drives to capacity of 5TB without any problem. ...
Feb 06, 2023Guru - Experienced User
Obiwan_ wrote:
I purchased some 16TB SSD usb drives
What did you buy?
The largest Crucial and Samsung external SSDs are 4 TB. I am thinking you might have gotten a scam drive (not having the capacity it claims).
Obiwan_
Feb 10, 2023Apprentice
The drives are available in various sizes 8, 16, 16 GB. See jpeg attached.
- Obiwan_Feb 10, 2023Apprentice
I pulled it apart and it is a scam. inside 64 gb micro ssd Son of a B- - - - H !!!!
One of the venders is wrapango.com
- SandsharkFeb 11, 2023Sensei
It would certainly be possible to cram a few M.2 SSDs into one external case, together with the necessary circuitry to concatenate them, but it would be quite expensive. Sorry you had to find out the hard way that one is too good to be true and I hope you can get your money back.
