DmitryS
Jun 18, 2019Aspirant
ReadyNAS RN3138 max LUN size
Hello! Could you please advise, is there any limit on LUN size on 3138? I try to expand my thick LUN, but the system tells that 8.4TB is the maximum size. Can I somehow expand my LUN beyond this value? P.S. This is not the free space issue, there is free space on the volume.
Thank you.
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
What is the total capacity of your volume? You should be able to expand your Thick LUN as long as it's below or within 90% of the total volume. Using Thin LUN is a different one since you can over allocate the size.
Please see LUN concepts
HTH
Regards
Total Capacity is 10.91TB you should atleast be able to set the LUN around 9.2TB with the 90% cap. Do you have any space consumed that is not used by the LUN?
you should be able to expand but if it's not letting there might be a condition not met or an issue that might need to be checked. Can you send me your logs through PM using Google drive?
Regards
