matthewhaymes
Jun 11, 2017Aspirant
ReadyNAS RN316 - mount_block_root+1f1 - Issues creating USB Recovery
Hi all THis morning my ReadyNAS 316 became unreachable via my network. Upon reset I received the following error - "mount_block_root+1f1". I cannot see the NAS via RAIDar. This thread - htt...
- Jun 13, 2017
Success!
I purchased a Lexar JumpDrive 8GB from Woolworths at lunch. Prepare it fresh using USB Recovery Tool and 6.7.4 on my work laptop.
First boot holding the OK button down, it looked like a few errors, but the LCD then showed "Booting...". After a minute, the NAS suddenly powered down. I powered it up again without pressing the OK button. LCD showed an error, complaing no drives were present. Powered down, inserted the drives. LCD showed "Booting..." then showed an increasing percentage. At 31% I went to grab a coffee - screen was blank when I got back. Booted up RAIDar on my Mac, and there it was.
Looks like all data and settings in place.
Is there anything I can send you to help root cause analysis or future troubleshooting?
matthewhaymes
Thank you for the response. I'm fairly confident I have done this correctly. I downloaded the ReadyNASOS-6.7.4-x86_64 ZIP file, then extracted the IMG file contained to the x86 folder. I've tried resetting the app and rebooting the OS, but the app still doesn't seem to recognise that the IMG file is in place.
matthewhaymes
Screenshots - https://goo.gl/photos/L4AZJXmEYmzatFm58
- mdgm-ntgrJun 12, 2017NETGEAR Employee Retired
Did you remember to right click on the tool and select to run it as an administrator?
- matthewhaymesJun 12, 2017Aspirant
Oh, no. I didn't know that was required - must've missed it in the instructions.
I just tested out this approach - unfortunately, with the same result.
Could the fact that I am running this on a VM through Parallels have an impact?
It might. So you're running this from a Mac?
You could try using a 3rd party tool such as Rufus in the VM instead. A syslinux bootable key with a MBR bootloader should work. You'd need to put the files on the USB key (in addition to the syslinux bootloader hidden files that Rufus would put on when creating a syslinux bootable USB key):initrd.gz
kernel
syslinux.cfg
ReadyNASOS-6.7.4-x86_64.img
NTGR_USBBOOT_INFO.txt
