lfrye
Jul 19, 2019Aspirant
ReadyNAS RN3220 Volume is Degraded but all green lights & no errors on disks
Hello, I'll start by stating I do not know what this "*Select Location" thing is while creating this discussion, so I apoligize if I used the wrong "Location". Here is the issue: I have a Ne...
JohnCM_S
Jul 20, 2019NETGEAR Employee Retired
Hi lfrye,
Can I send you the logs via OneDrive link?
Yes, you can send the logs via OneDrive link.
Regards
lfrye
Jul 22, 2019Aspirant
Good morning,
I just sent the logs over to John in a PM.
Thank you,
Leif
- JohnCM_SJul 23, 2019NETGEAR Employee Retired
Hi lfrye,
I just saw your logs and it looks like disk 2 is already marked as faulty.
md127 : active raid6 sde3[0] sda3[8] sdb3[5] sdc3[6] sdd3[7] sdi3[3] sdh3[2] sdf3[1](F)
17552488704 blocks super 1.2 level 6, 64k chunk, algorithm 2 [8/7] [U_UUUUUU]Checking the disk_info.log, there are 5 current pending sectors on your disk 2.
Device: sdf
Controller: 0
Channel: 1
Model: WDC WD3000FYYZ-01UL1B1
Serial: XXXXXX
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 5
Uncorrectable Sector Count: 0RAID 6 has 2 parity drives but if one fails, it is still degraded. The volume becomes degraded whenever one drive outside of the total number is out.
