lfrye
Jul 19, 2019Aspirant
ReadyNAS RN3220 Volume is Degraded but all green lights & no errors on disks
Hello, I'll start by stating I do not know what this "*Select Location" thing is while creating this discussion, so I apoligize if I used the wrong "Location". Here is the issue: I have a Ne...
Jul 30, 2019Guru - Experienced User
lfrye wrote:
We replaced the drive but it is not rebuilding. How do I make it rebuild the disk? It currently says the state is healthy but has been stuck on "Balancing in progress 0% complete" since we replaced the drive 4 days ago.
Odd. Did you start the balance before you replaced the drive?
Can you download the log zip file and post mdstat.log (copy/paste it into a reply).
lfrye
Jul 30, 2019Aspirant
Sure can, please see below from mdstat.log: (Edit: balance was done after neww drive was installed)
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md127 : active raid6 sdj3[9] sde3[0] sda3[8] sdb3[5] sdc3[6] sdd3[7] sdi3[3] sdh3[2]
17552488704 blocks super 1.2 level 6, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
md1 : active raid6 sde2[0] sdc2[6] sdd2[5] sdb2[4] sdh2[3] sdi2[2]
2616320 blocks super 1.2 level 6, 512k chunk, algorithm 2 [7/6] [U_UUUUU]
md0 : active raid1 sdj1[9] sde1[0] sda1[8] sdb1[5] sdc1[6] sdd1[7] sdi1[3] sdh1[2]
4190208 blocks super 1.2 [8/8] [UUUUUUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Thu Jun 5 23:12:24 2014
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 8
Total Devices : 8
Persistence : Superblock is persistent
Update Time : Tue Jul 30 13:47:23 2019
State : clean
Active Devices : 8
Working Devices : 8
Failed Devices : 0
Spare Devices : 0
Name : 7c6ed9ac:0 (local to host 7c6ed9ac)
UUID : 361ae6a0:cb42991e:df5b94fb:3de50d5a
Events : 3021
Number Major Minor RaidDevice State
0 8 65 0 active sync /dev/sde1
9 8 145 1 active sync /dev/sdj1
2 8 113 2 active sync /dev/sdh1
3 8 129 3 active sync /dev/sdi1
7 8 49 4 active sync /dev/sdd1
6 8 33 5 active sync /dev/sdc1
5 8 17 6 active sync /dev/sdb1
8 8 1 7 active sync /dev/sda1
/dev/md/1:
Version : 1.2
Creation Time : Tue Mar 13 18:36:51 2018
Raid Level : raid6
Array Size : 2616320 (2.50 GiB 2.68 GB)
Used Dev Size : 523264 (511.00 MiB 535.82 MB)
Raid Devices : 7
Total Devices : 6
Update Time : Tue Jul 30 13:46:52 2019
State : clean, degraded
Active Devices : 6
Working Devices : 6
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 512K
Name : 7c6ed9ac:1 (local to host 7c6ed9ac)
UUID : 3ff1d12b:7b93ca9f:4d63b3c7:5ca60a6c
Events : 2261
0 8 66 0 active sync /dev/sde2
- 0 0 1 removed
2 8 130 2 active sync /dev/sdi2
3 8 114 3 active sync /dev/sdh2
4 8 18 4 active sync /dev/sdb2
5 8 50 5 active sync /dev/sdd2
6 8 34 6 active sync /dev/sdc2
/dev/md/data-0:
Version : 1.2
Raid Level : raid6
Array Size : 17552488704 (16739.36 GiB 17973.75 GB)
Used Dev Size : 2925414784 (2789.89 GiB 2995.62 GB)
Raid Devices : 8
Total Devices : 8
Update Time : Sat Jul 27 17:52:18 2019
State : clean
Active Devices : 8
Working Devices : 8
Failed Devices : 0
Spare Devices : 0
Chunk Size : 64K
Name : 7c6ed9ac:data-0 (local to host 7c6ed9ac)
UUID : 0dddc1d7:3cce3178:52db493d:44f5e2ab
Events : 130974
0 8 67 0 active sync /dev/sde3
9 8 147 1 active sync /dev/sdj3
2 8 115 2 active sync /dev/sdh3
3 8 131 3 active sync /dev/sdi3
7 8 51 4 active sync /dev/sdd3
6 8 35 5 active sync /dev/sdc3
5 8 19 6 active sync /dev/sdb3
8 8 3 7 active sync /dev/sda3
