lfrye
Jul 19, 2019Aspirant
ReadyNAS RN3220 Volume is Degraded but all green lights & no errors on disks
Hello, I'll start by stating I do not know what this "*Select Location" thing is while creating this discussion, so I apoligize if I used the wrong "Location". Here is the issue: I have a Ne...
lfrye
Aug 05, 2019Aspirant
Hi StephenB,
There is not a drive with sdj labeling. I have drives labeled sda-sdi.
After rebooting the NAS device the RAID 6 rebuilt and appears good.
Thank you for your follow up,
Leif
Aug 05, 2019Guru - Experienced User
Likely the drive got relabeled when you rebooted.
Get a fresh set of logs, and look at mdstat again. Make sure that md1 lends with algorithm 2 [8/8] [UUUUUUUU] - with no _ in the [U...] part.
- lfryeAug 05, 2019Aspirant
No underscores in the U strings. See below:
md1 : active raid10 sda2[7] sdb2[6] sdi2[5] sdc2[4] sdd2[3] sdh2[2] sdf2[1] sde2[0]
2093056 blocks super 1.2 512K chunks 2 near-copies [8/8] [UUUUUUUU]
md127 : active raid6 sde3[0] sda3[8] sdb3[5] sdc3[6] sdd3[7] sdi3[3] sdh3[2] sdf3[9]
17552488704 blocks super 1.2 level 6, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
md0 : active raid1 sde1[0] sda1[8] sdb1[5] sdc1[6] sdd1[7] sdi1[3] sdh1[2] sdf1[9]
4190208 blocks super 1.2 [8/8] [UUUUUUUU] - StephenBAug 05, 2019Guru - Experienced User
Great - everything looks fine.
Thank you StephenB for your follow though. I truly appreciate it.
Thank you,
Leif
