bmahulkar19's avatar
bmahulkar19
Follower
Aug 31, 2015
ReadyNAS Rn4220 showing 169.254.168.203 and red light is blinking on the front panel
I have ReadyNSA RN4220 and need to configure, but in NETGEAR readynas raidar utility the IP address is 169.254.168.203 and on front panel of the storage the red light is blinnking...??
I need to access the broswer with the deafult IP..is that any way i can access it...?
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Try setting the I.P. of your PC to e.g. 169.254.168.100. Then you should be able to connect, configure the NAS then change the I.P. of your PC back to what you want it to be.
    As for the red light that is likely not a cause for concern.
ProSupport for Business
