Connor158910
Jun 09, 2025Guide
Readynas RND-6a doesn't boot
I got this NAS used and so am unsure as to how it works. The model is Readynas rnd-6a. When I power it on the fans spin up and "ReadyNAS" displays on the LCD but that is all. I assume it doesn't ...
- Jun 19, 2025
For those who might be asking similar questions one day. There was no solution. Unfortunately, such an issue is in "buy a new NAS" territory.
Sandshark
Jun 09, 2025Sensei
"RND-6A" is not a ReadyNAS model number. I have no idea why Netgear put those useless numbers on them. What is the model number of the NAS (example: RNDP6000-100)?
Connor158910
Jun 09, 2025Guide
I'm not 100% sure on how to check the model number. The only model listed on the bottom of the device was the "RND-6A" as it seems the model name sticker is missing.
Photo attatched below.
Are there any other ways to check? It looks most similar to https://www.netgear.com/support/product/rndp6000-200_readynas_pro_6/
Although the bottom right on the front only says "ReadyNAS" not "ReadyNAS Pro"
Thanks!
