Connor158910
Jun 09, 2025Guide
Readynas RND-6a doesn't boot
I got this NAS used and so am unsure as to how it works. The model is Readynas rnd-6a. When I power it on the fans spin up and "ReadyNAS" displays on the LCD but that is all. I assume it doesn't ...
- Jun 19, 2025
For those who might be asking similar questions one day. There was no solution. Unfortunately, such an issue is in "buy a new NAS" territory.
Connor158910
Jun 10, 2025Guide
Thanks for the reply. I have no disks in the NAS at all.
Jun 10, 2025Guru - Experienced User
Connor158910 wrote:I have no disks in the NAS at all.
Then it should say "No disks" on the LCD panel, and should get an IP address from your router.
Is this a used NAS you just purchased, or did it work for you at some point in the past?
