Connor158910
Jun 09, 2025Guide
Readynas RND-6a doesn't boot
I got this NAS used and so am unsure as to how it works. The model is Readynas rnd-6a. When I power it on the fans spin up and "ReadyNAS" displays on the LCD but that is all. I assume it doesn't ...
- Jun 19, 2025
For those who might be asking similar questions one day. There was no solution. Unfortunately, such an issue is in "buy a new NAS" territory.
Rottenweiler
Jun 15, 2025Guide
Most of the Ultra 6 models I have worked on have a blue colored main PCB. (Versus the RN Pro 6's which have all been standard green color) You can "see" the blue PCB thru the fan vent on the side. Might help you? (NOT sure that is 100% rule, just my experience)
Sandshark
Jun 15, 2025Sensei
If you see a motherboard through the vent holes that are in the shape of a fan, it's an Ultra6. The Ultra6Pro and all 6-bay Pro models have a fan there.
