ChrisCClassen
Aug 02, 2021Aspirant
ReadyNAS RND2000 v2
ready nas is bricked drive 1 dead drive 2 has lots of data and the drive tests good but I cannot access any files created or modified after 4/5/2021 testdisk (under ubuntu) runs and doesn't find a...
ChrisCClassen
yes. tried all combinations.
the nas does not respond to any outside input. no access to boot menu, even tried attaching a serial monitor.
more concerned about retreiving the data.
other solutions to cover data loss now than when I implemented this.
abandoning the ready nas as a solution. past EOL now anyway.
Aug 02, 2021Guru - Experienced User
You could try r-linux for windows: https://www.r-studio.com/free-linux-recovery/
This will only work on one of the two disks (typically the first).
- ChrisCClassenAug 02, 2021Aspirant
r-linux has helped get some data. just not getting the recent stuff
