flinx
Mar 28, 2017Aspirant
ReadyNAS RND4000 not recognised on network
Started randomly not being recognised on a windows 10 network but now halts at "booting". the discs spin up but go no furthur. The buttons on the unit do not do anything anymore. i have tried acces...
- Apr 15, 2017
evan2 wrote:
4x1TB can't transfer from RND4000 to RN214,
RND4000 is 4.x FW, data is using EXT4 filesystem, RN214 is 6.x FW, data is using btrfs filesystem.
The RND4000 disks can be mounted on the RN214 with assistance from paid support. This is read-only, so the files then need to be copied off.
evan2
Apr 11, 2017NETGEAR Expert
- StephenBApr 15, 2017Guru - Experienced User
