kwandh
Aug 11, 2023Follower
ReadyNas RND4000 V4 cannot connect with remote server
Model: Ready NAS NV+ V2; Firmware 5.3.5 Windows 10 Pro "A connection to the server could not be established; this error may occur if you are on a network that uses a proxy server or if you hav...
Aug 12, 2023Guru - Experienced User
I'm surprised you were able to use Ready Remote with the NV+ v2, as Netgear deprecated it back in September 2017.
It was replaced with ReadyCloud, which only supported OS-6 NAS. That was turned off last month.
You will need another solution for remote access. Personally I use the Open VPN service built into my Orbi router.
Firmware 5.3.5
I suggest upgrading the firmware to the final version (5.3.13)
Also, if you are working around ssl protocol/cipher mismatch errors when you browse to the NAS admin ui, there is an add-on you can install to add TLS 1.2 support to your NAS.
- MusharafAug 18, 2023Aspirant
can you please advise from where I can get TLS 1.2 support add on.
Thanks
- StephenBAug 18, 2023Guru - Experienced User
What firmware is your NAS running???
Hi,
using RAIDiator 5.3.13
and getting below error:uses an unsupported protocol.
"ERR_SSL_VERSION_OR_CIPHER_MISMATCH"Thanks
