kwandh
Aug 12, 2023Follower
ReadyNas RND4000 V4 cannot connect with remote server
Model: Ready NAS NV+ V2; Firmware 5.3.5 Windows 10 Pro "A connection to the server could not be established; this error may occur if you are on a network that uses a proxy server or if you hav...
Musharaf
Aug 18, 2023Aspirant
Hi,
using RAIDiator 5.3.13
and getting below error:
uses an unsupported protocol.
"ERR_SSL_VERSION_OR_CIPHER_MISMATCH"
Thanks
Aug 19, 2023Guru - Experienced User
The add-on you can use is here:
If you have internet explorer installed on the PC, that should still connect to the web ui so you can install the add-on. Edge in IE mode is also supposed to connect.
Another option is to use FireFox - there is a setting there that will let you enable legacy TLS.
- In a new tab, type or paste about:config in the address bar and press Enter/Return. Click the button promising to be careful.
- In the search box above the list, type or paste security.tls.version
- Set the security.tls.version.min preference to 1
Best to set this back to 3 after you have successfully installed the add-on.
- MusharafAug 20, 2023Aspirant
Many thanks, it worked.
