BMac2021
Sep 26, 2023Tutor
ReadyNAS RNDP6000-Parts? Wont power on.
Good morning group. I wrote a while back about my display not working on the front door of my ReadyNASRNDP6000. I now have a bigger issue...The unit wont turn on at all. Does anyone have the tech man...
- Sep 26, 2023
New PSU ordered..
https://www.amazon.ca/gp/product/B01MEDG1PM/ref=sw_img_1?smid=AEHA1AAWZIC3L&th=1
And cable extension....
thanks for the help...
Sep 26, 2023Guru - Experienced User
BMac2021 wrote:
I wrote a while back about my display not working on the front door of my ReadyNASRNDP6000. I now have a bigger issue...The unit wont turn on at all. Does anyone have the tech manual on this unit.
There is no tech manual, but you can replace the PSU.
I'm tagging Sandshark as he often gives useful advice on options.
You can also find some that claim to be compatible.
