nickpea
Feb 18, 2019Aspirant
ReadyNAS RNDU2120-100AUS
Hi I have a ReadyNAS (RNDU2120-100AUS) dual bay with 2 x 1TB drives. The drives are fine, but the chassis has failed. The same model NAS is no longer available. If I purchase a new equivalent unit...
- Feb 18, 2019
Hi nickpea
Welcome to the Community!
Provided that your NAS drives are healthy the best path is to purchase a ReadyNAS OS 6 Unit which has x86 processor as well like the RN400 series and up. Though the steps to migrate the data or transfer the data to the newer unit is not as simple as installing the drives and boot them. Please see ReadyNAS Migrate and Data recovery services might be needed, But this path will get you to be working with the latest updates and hardware.
On the other hand finding a similar model (Ultra 2) for sale refurbished online within a reasonable price is another option.
Hope this helps!
Regards
nickpea
Great - thanks for your help
Sandshark
Feb 18, 2019Sensei
There are also plenty of other compatible models into which you can install your drives as-is. Anything that runs OS4.2.x. It is best to use a spare drive and verify the firmware is up to the same version yours was before you migrate the drives.
Note that this is one of the good reasons to upgrade compatible legacy models (any 64-bit Intel based model) to OS6. If you had been running OS6, you could simply move the drives over to a new OS6 model.
