egprod77
Aug 28, 2020Aspirant
ReadyNas RR230400 RAID 5 PARAMETERS
Hi I have a ReadyNas RR230400, the data is no longer accessible but still in the server, empty folder... I am doing a file search with R-Studio, what are the original Netgear X-RAID 5 settings, R...
- Aug 28, 2020
R-Studio won't work. Your NAS (which runs OS-6 firmware) uses BTRFS as the file system. R-Studio doesn't support that file system.
You'll need to use the more expensive ReclaiMe software. https://www.reclaime.com/
Aug 28, 2020Guru - Experienced User
- egprod77Aug 31, 2020Aspirant
Hi
I use this software (150€) , it works perfecly I found and save 6To fo datas on my Nas Raid 5,
I mount the 4 HDD in my Mac for this .
https://www.ufsexplorer.com/ufs-explorer-raid-recovery.php
